Gem module
Gem module
Hey guys new to the forum. I have a 2012 f350. From what i've found form reading on other forums, it seems I'm having problems with my gem module. Can someone please help me with the location on my 2012? Fuse box is on the passenger side of the truck. Is the gem behind it like on previous years?
Thanks!
Thanks!
When you step on the gas, I loose all dash, gages, radio briefly. Sometimes the air will turn on full blast before instruments come back on and doors will lock even though they are already locked. Smelled a burning electrical smell a week ago and now this started. Just not sure were to start
Trav402 - I'm sure someone has had your issue even though it's a new one for me. Like resident tech Senix said, sounds (or smells) like you have a short to find. Modules are all over the truck.
One place that is a culprit for bizarre behavior are the connectors and ground by the e-brake pedal. I'll try to get one of the FTE members that had that issue to chime in whether they ever had a smell with the problem. I don't remember any one saying they smelled burning, but a loose ground arcing could.
Do you use your ebrake/parking brake a lot?
IMHO, I'd check that area first... Then looking at the other easily exposed areas of wire in the truck and under the hood would be place #2. Just in case, I'd check all my fuses as well. Might be able to help you narrow down where to look if one is blown...
Not a fan of electrical issues either (who is?) as you spend hours and hours tracking it down.
THE BLUE HEAP
03-09-2010 12:26 PM
beeshoo
04-15-2007 01:52 PM
