1948 f1 transmission/clutch "stuck"
Ok.. so i'm trying to push my clutch pedal to move the transmission clutch fork/throw out bearing so i can move thru my 3 spd transmission and the clutch pedal to transmission lever hardly moves..maybe 1/4 inch and even so still cant get the transmission to shift thru gears..I think my transmission lever isn't moving enough..sorry for the laymen explanation/description of what I'm dealing with but any thoughts of what might be my problem?
ok so I opened up the inspection plate and from what I can see the clutch fork and the bearing are moving freely BUT..the fork that pushes the bearing onto the clutch pressure plate doesn't move the clutch?? view showing the fork, bearing pressing up against the pressure plate fingers which wont press forward with the bearing
Ok..so here r some pics of trani..not rusted just orange color..grease? Turns smoothly..
Clutch shaft moves smoothly when turned and springs back as supposed to..my problem appears to be in the pressure plate..is itb installed correctly? or did I buy the wrong clutch plate that maybe I should of purchased along with the pressure plate to be absolutely sure the two were compatible?..plate went onto the spline just fine..so aren't those clutch fingers not budgeting when in turn the clutch shaft lever?
