2005 And up fog lights, Will they fit an 04?
I don't know about that brand you have referenced, but..............
When it comes to the Super Dooties, from 2001-2004 they used the same stock part number for the fog light assemblies.
2005-2007 they used a different one then the previous years.
When you look at 2001-2004 fog light assembly it looks like the mounting bracket is recessed more than that of the 2005-2007.
This is from the stock fog assembly standpoint.
So to be safe you may want to just order for the year of your truck, the 2001-2004 era.
Hope that helps.
- Preston
Actually, now that I think of it, you could probably order a 2005-2007 set but have to mount them on the 2001-2004 brackets that come with your truck.
The stock bulb housing looks the same between 2001-2007, but the bracket looks different.
You don't reference a website link. That would probably help you get an answer too.
I like these ones:
Ford Super Duty XB LED - Fog Lights from Morimoto HID
And they state that they are compatible with 1999-2016 Super Dooties
Compatibility
REPLACES FORD PART #:
6C3Z-15200-AA, 6C3Z-15200-BA, 7C3Z15200AA, 7C3Z15201AA, BC3Z15200A, BC3Z15201A, XL3Z13466A
FORD EXCURSION:
1999-2016
FORD SUPERDUTY:
1999-2016
CERTIFICATIONS:
DOT, ECE, SAE
NOTE:
1999-2010 Trucks Req. Minor Modification!
