93 F250 turn signal and brake lights out
[updated:LAST EDITED ON 11-Dec-01 AT 10:57 AM (EST)]Turn signal on dash, and of coarse, back and front aren't working. Checked fuses, fine, but in the process saw the ABS begin blinking. Shut off engine, tried again, everything worked for about a minute, then dead again. Redoing the same process gave me the same results.Any ideas ? or is this as simple as changing the bulbs? I am a school teacher and I need to fix this on my break... Thanks.
I have seen the multi switch cause this problem, It is the compleate turn signal controler behind the steering wheel, it takes a little experiance to cachange it and I believe it costs some where between $50-$100, but I have seen them go out and this is what it causes.
