Bad Brake Booster
Old 03-02-2017, 07:50 PM
*2fords*'s Avatar
*2fords*
*2fords* is offline
Bad Brake Booster
MY brake booster is bad and I will be getting it replaced Saturday after next. It doesn't appear to be effecting anything and my brakes work fine. As fine as they are I guess.
My question is, even tho it don't appear to be effecting anything, is it really not effecting anything? Am I missing anything?
Old 03-02-2017, 07:58 PM
Willigaf's Avatar
Willigaf
Willigaf is offline
How do you know it's bad?
Old 03-02-2017, 10:15 PM
*2fords*'s Avatar
*2fords*
*2fords* is offline
Because I step on brake pedal and Ii get a sucking air sound. And it continues for a short while after I take my foot off the brake pedal.
Old 03-03-2017, 08:04 AM
tjc transport's Avatar
tjc transport
tjc transport is offline
i ain't rite
Received 3,081 Likes on 2,151 Posts
the only thing it will really do is give you low vacuum in the engine.
Old 03-03-2017, 07:34 PM
*2fords*'s Avatar
*2fords*
*2fords* is offline
That's what I was thinking, but nothing seems to change when my foot is on the brake. Unless it's a constant thing, and will improve once the booster is replaced.
I was thinking tho, that the engine wouldn't be running right or at all with a vacuum leak.
Maybe the rotten gas mileage will improve too.
I just figured I'd ask, since it seems everything effect everything on these trucks. I didn't want to miss anything or probably damage something because i can't get it fixed right away.
Old 03-05-2017, 03:14 PM
Willigaf's Avatar
Willigaf
Willigaf is offline
You know about the zero loss booster? I think it's standard replacement now if you look at the numbers on rockauto. Believe it was intended for 1997 250/350 models but pretty sure the number is the same between 92-96. At least it is for a 94 f250 on rockauto.
Old 03-05-2017, 08:02 PM
*2fords*'s Avatar
*2fords*
*2fords* is offline
I've never heard of it.
I'm not exactly sure what no loss even means. no loss of vacuum? Is it an improvement over the stock one?
I'm getting a new one installed Saturday, I wonder if the shop will install one not intended for my truck.
Well I went and check Rockauto, and Oreillys. They are the same so I guess that's what I'm getting.
Oreillys is 10.00 more on both cost and core charge.
Old 03-05-2017, 09:18 PM
Willigaf's Avatar
Willigaf
Willigaf is offline
Somebody discovered it as their magic fix in one of the brake threads. Which truck is the booster going on? And have you thought about installing it yourself?
Old 03-06-2017, 07:32 PM
*2fords*'s Avatar
*2fords*
*2fords* is offline
it's going on my 93 F-250.
No I haven't thought about it. I don't have the time nor the want to do it.
Everytime I try to fix anything on these trucks, something else goes wrong. Usually something so simple turns out to be a major PITA.
So I'd rather pay someone else to deal with it.
Old 03-12-2017, 11:08 AM
Willigaf's Avatar
Willigaf
Willigaf is offline
Fair enough. I've also had that issue, take on one repair and either create or discover some other problem. Saw your reply on the other booster thread. No change at your pedal after you had the new booster installed? Did the whooshing or sucking go away, or no?
Old 03-12-2017, 08:32 PM
*2fords*'s Avatar
*2fords*
*2fords* is offline
Oh yes the whooshing is gone. It's so nice to not hear that any more.
Just have to figure out why the pedal didn't improve.
Old 03-12-2017, 10:23 PM
Willigaf's Avatar
Willigaf
Willigaf is offline
Keep us posted with your efforts and outcomes. The soft pedal threads rarely get the final update on what was the cause of the problem. Can I assume you've been through adjusting the drums, bleeding at each wheel and the RABS?
Are your rubber brake lines in good condition? Any loss of fluid in the master cylinder? Kind of chasing my own pedal problem. Truck stops great but pedal is not confidence inspiring.
F-250 WARHORSE
15
01-21-2017 01:33 PM
z 97ford1
1997 - 2003 F150
11-28-2015 03:42 PM
FIREPHIL
12-06-2011 08:42 AM
gtuttle
05-05-2009 01:06 PM
Quick Reply: Bad Brake Booster
