Why am I only getting 6 volts going to my coil??? - Ford Truck Enthusiasts Forums
Old 08-30-2003, 12:26 AM
dirtbu11y dirtbu11y is offline
dirtbu11y is starting off with a positive reputation.
Question Why am I only getting 6 volts going to my coil???
84 302 F150 auto 4x4 carb and dura-spark
the leads to the coil only have six volts when starting
truck stoped running so I don't what I have for running voltage
took the box to autozone and it tested good twice
going to try the connections tomorrow
does anyone know who sells the plugs to connect the ignition box to the harness???? pn????
my car blew up the day after I bought this truck so I NEED it to run!!!!
good news is I bought a $300 truck and the 4wheel drive works!!
Old 08-30-2003, 02:16 AM
Ford_Six's Avatar
Ford_Six Ford_Six is offline
Ford_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputation
With the key on, see if there is a voltage drop between the distributor body and the battery negative post. Also, if you just need to get it running, splice the wires with suitcase connectors (aka tap splices, Scotch Locks). You don't have to cut off the connectors, and you can pull the splices back off later when you fix the plugs.
Old 08-30-2003, 09:34 AM
just to make sure we are on the same page can you give me a play by play on looking for that voltage drop?????
Old 08-30-2003, 09:56 PM
1987LTDmasta's Avatar
1987LTDmasta 1987LTDmasta is offline
1987LTDmasta is starting off with a positive reputation.
6V is completley normal for a coul during cranking, esp if your using a Digital Voltmeter. there is a constant fluctuation of 12V to 0 V then back to 12V and this happens very rapidly. why?
ignition coils basically make power. the 12v is used to create a small magnetic field around a winding of coil. once the power is cut off from that magnetic field, that magnetic field collaspes into the coil, creating an intense spark. that spark is then sent to the dist ad down to a spark plug. it must do this rapidly to be able to provide a spark for each cylinder at x-amount of RPMs.. the igntition module on electronic systems controls the speed of the power to the coil. pre-electronic systems, a point (or basically a switch) did this contant on-off power to the coil. there was a "bump" for everey cylinder on a small rotating cam inside the distributor. these bumps would kick off the point, turning off the coil and creating the spark. each bump was aligned with a cylinder.
anyway enough lefture, 6V at the coil during cranking is normal. due to the consant fluctuation of 0-12V.. and whats in between 0 and 12V? 6V.. Digital Voltmeters read the average voltage when theres a constant fluctuation. if you were to try an analog meter, you might be able to notice the flickering.
56 Panel not starting Coachkev70 1948 - 1956 F1, F100 & Larger F-Series Trucks 29 10-02-2016 03:37 PM
Coil Questions pickenspolitics 1973 - 1979 F-100 & Larger F-Series Trucks 7 09-27-2015 05:24 PM
3 VOLTS AT COIL+.....RESISTOR WIRE FAILURE???? 78 Ford F150 460 1973 - 1979 F-100 & Larger F-Series Trucks 38 07-28-2015 08:51 AM
Ignition Help Jmschneider 1973 - 1979 F-100 & Larger F-Series Trucks 3 07-21-2015 09:51 AM
1956 F100 ignition coil low voltage Moiford 1948 - 1956 F1, F100 & Larger F-Series Trucks 6 07-11-2015 02:20 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
