Trying to figure out what happened here
Old 03-01-2017, 04:19 PM
swellman's Avatar
swellman
swellman is offline
Hello,
Bought a 95 Ford F-150 with the 302 V8 engine. I have been noticing that I am loosing a lot of fluid and was thinking it was the radiator. However, I noticed this pipe is missing a hose and the hose has been bypassed. I believe this goes to the transmission can anyone verify this? Thanks.
Old 03-01-2017, 04:46 PM
rla2005's Avatar
rla2005
rla2005 is online now
Received 1,152 Likes on 910 Posts
The hose below the radiator cap with the plug in it is supposed to supply warm water to the throttlebody to aid atomization during cold weather.
The metal lines below that are for the transmission cooler. I hope the previous owner did that because they installed an auxiliary air to fluid cooler in front of the radiator.
Old 03-01-2017, 04:51 PM
swellman's Avatar
swellman
swellman is offline
Thank you rla2005. There is no other cooler to the transmission that I can see. How could I fix this? Not really sure where the pipes go that he cut. Can't really find any schematics of the system.
Old 03-01-2017, 04:57 PM
rla2005's Avatar
rla2005
Basic block drawing:
The diagram is showing the air to fluid cooler in the upper left of the photo.
I know the F250/350 usually have the radiator mounted cooler then an inline air-fluid trans. fluid cooler mounted in front of the radiator. F150/Bronco that may be optional.
At the very least you should have some sort of cooler installed. Most use the radiator cooler and an even larger aftermarket cooler in front of the radiator. If that truck has been running around with no cooler for very long the transmission may be toast.
My4Fordtrucks's Avatar
My4Fordtrucks
My4Fordtrucks is online now
Received 1,344 Likes on 1,061 Posts
What fluid are you losing a lot of: antifreeze for ATF?
Suppose it's possible that the trans cooler in the radiator is bad so the PO bypassed it.
Old 03-01-2017, 04:58 PM
dixie460's Avatar
dixie460
dixie460 is offline
Look at your transmission. From the factory there would be two steel lines running out of the side towards the front of the truck. If you have a factory auxiliary oil cooler then one line will run to that cooler (in front of the condenser which is in front of the radiator) and the other will go to the radiator. Then between the radiator and the aux cooler there will be a third line.
If your truck does not have the factory aux cooler then both lines will come out of the transmission and run direct to the radiator.
If the previous owner did what I think he did, both lines now come out of the transmission and run to an aftermarket cooler.
All you have to do is follow the lines out of the transmission and see where they go... then you'll know what you're working with.
Edit: And I see RLA beat me to it with a picture which explains the two possible factory configurations nicely.
Old 03-01-2017, 05:04 PM
swellman's Avatar
swellman
swellman is offline
Thanks for all the quick help. My4Fordtrucks I am loosing antifreeze fluid. I fill the reservoir jug to the cold level but in 3-4 days the reservoir is empty. I will crawl under the truck this and see where these lines go to now...hopefully there is an aftermarket cooler. Just curious, could I drive the truck several hours without any coolant or coolant system cooling the tranny or would it have broke down by now? I have owned it 2 months and have driven it almost daily 30-50 miles per day. Thanks again everyone.
Old 03-01-2017, 05:17 PM
dixie460's Avatar
dixie460
dixie460 is offline
Ehh... it really depends on how you drive the truck and what the weather is like. On the highway you MIGHT be okay but around town I cant see that happening without overheating the transmission.
However... if you didn't get a flashing OD light (on the end of the gearshift) then you might be okay. Because overheating the transmission will set a fault code and cause the light to flash.
Old 03-01-2017, 06:03 PM
swellman's Avatar
swellman
swellman is offline
Thanks dixie460...I will keep an eye on the OD light. It looks like I do have an air cooler installed...still can't find where the leak is. Let it run for 15 minutes and nothing obvious...could be leaving through the exhaust I guess.
Old 03-01-2017, 06:32 PM
Glenn54's Avatar
Glenn54
Glenn54 is offline
Maybe the coolant reservoir or the hose going to it that is leaking? I'm pretty sure I have the same problem but haven't taken the time to check it.
Truckman8719
07-23-2018 05:49 PM
Deagle12
03-31-2018 02:45 PM
Aaron-71
08-17-2015 02:26 PM
FORDSDOWNER
1999 to 2016 Super Duty
08-18-2007 10:14 PM
patriotguard31012
07-02-2007 09:39 AM
Quick Reply: Trying to figure out what happened here
