1990 460 rough idle, stalls
My 1990 F250 4x4 with a 460 ran great then all of a sudden has a rough idle, and as you go to step on the throttle will stall. I've pulled the codes, and get:
KOEO: 11
CM: 11
If I'm reading these right, that means according to the "system" it's fine
It starts right up, but is almost impossible to drive, unless your on some back road where you never have to stop.
KOEO: 11
CM: 11
The F-series gas engine trucks stopped using the three pump setup after 1989. 1990 and later trucks use the two pump system. Each tank has it's own high pressure pump.
VONxRUBENxLA
17
02-16-2023 10:21 AM
gtikid86
22
09-30-2011 09:43 PM
McCormick
09-18-2010 10:59 AM
