Cab drone
on
I had an 06 xtracab V10 and had no cab noise! I would look at the exhaust and see if its been changed at all. The hangers should be rubber insulated. If one isn't it will vibrate and transmit that to the cab. I did a custom exhaust when I was young and I mounted solid hangers. The truck vibrated horribly in the cab.
I'm kind of thinking you're hearing something other than exhaust noise in the cab, my 06 with stock exhaust had zero exhaust noise in the cab.... on second thought at around 100k the exhaust manifolds started leaking, 14 of the 20 manifold stud nuts were loose. After retightening the exhaust leak is still gone at 120k, but I could definitely hear it outside.
Is the sound engine speed related or vehicle speed related?
twigsV10 - not much to describe.... sounds like exhaust, gets louder the higher the rpms are but only when under load. When it shifts and the rpms drop it gets quieter and then builds as rpms increase.
Definitely engine speed related and coming from the rear of the vehicle. This weekend I'll have a chance to crawl under and look at it closer, making sure to check for loose heat shields or missing hangers.
that's what I said in my deleted post! :-)
I made some jokes about a previous owner… And Krewat thought I was being sarcastic with the OP
Took a look underneath the truck yesterday and found the two heat shields on the muffler itself were missing one of the bands that holds them on, also two of the rubber insulators were incorrectly installed. Fixed those and got a test drive in and while it is a little quieter I would like to tone it down some more. Any ideas?
I strongly believe your exhaust system has been modified from stock, by the previous owner. Let us know what you find.
And if I offended you with my (deleted post) comments about the previous owner; I'm sincerely sorry.
And!!
Ever since I straight-pipe-deleted my catalytic converters, I've been a little annoyed with the extra noise in my van. I've had the idea to add header wrap or something similar. Also I thought about making some homemade heat shields (similar) and welding them on the pipes as an extra barrier between the path from the straight pipes to my ears.
Seems like a good idea.
does it have a resonator? If it came with one from the factory and doesn't have one now - that'll probably do it.
Very possible that it has been modified but I don't see anything that would suggest it. Possibly a cat back system that either reused or came with clamp on heat shields for the muffler.
Your post was actually deleted before I saw it. Even if it hadn't been I wouldn't have cared; I don't know who the previous owners were.
Also found another section of loose heat shield before the y. Went for a short drive but had the rear windows open for my dog so I could discern drone from regular exterior noise. On a side note it may have more exterior sound than I thought. Current muffler is starting to rust through (possible cause) so I'll be in the market for a replacement eventually anyway.
Update: The last heat shield that I tightend up seems to have done the trick. Acceptable noise level, hell it even sounds dare I say nice. Just waiting on the 5star tuner to show up today or tomorrow. Thanks for the help everyone.
brethren33
1999 to 2016 Super Duty
02-27-2019 09:16 AM
