side mirror swivel
I bought a couple mirrors for my 62 Merc truck at a swap meet a couple weeks ago and the mirror heads are loose as well. Another guy at the swap meet said to take a centre punch and hammer a couple peens on the ball and it will tighten it up. I haven't tried it yet to see if it will work. I want ro pull the glass out first so I don't break it. ,Doug
Had success on my '66 tonight. Loosen the set screw and pull the mirror and ball joint out of the bracket.
Pulling the mirror. Set it flat and push the mirror in. It is spring loaded. Work the retaining clip out and remove the mirror. I used a razor utility blade.
Retainer clip for mirror. Once the mirror is out, tighten the ball tension with the nut. Good as new!
Tension screw for the ball joint behind mirror.
laynrubber
01-24-2005 03:54 PM
