7.5 to 7.3 swap!
Swap the engine into the 95. Should have no fitment issues, but some modification will be necessary. I would try and find a truck that's been totaled and pull the wiring harness, and take the heat shield that is mounted on the firewall to the trans tunnel, you'll want that for sure. I think you can modify the ZF5 on the 460 to work, and could probably do that for a little while, but I'd look for a 7.3 ZF5 either for an IDI or a powerstroke because both will work. Or, an early ZF6. Bubba Should know quite a bit since he converted a gas 302 Bronco 5 speed to a 7.3 Power stroke 5 speed bronco.
Bigred1971
12-06-2015 08:06 AM
Orpackrat
17
08-04-2013 11:59 PM
Shwan_89HD
15
01-24-2012 09:43 PM
Midwest Dually
General Diesel Discussion
03-29-2010 12:43 PM
