CJ-4 OIL getting harder to find....
#46
CJ-4 is still acceptable and what many people in this thread are searching for. The problem seems to be the CK-4 oil meeting Ford specs.
#48
#49
Shell ROTELLA® Responds to Ford?s Position Statement | Shell ROTELLA®
#50
ok lets then ask the question... who runs T-6? who runs T-5? is there a difference in milage before oil change is needed? or oil analysis?
I only use mine as a DD, if it was used for Hot Shot or something else then the oil change intervial would be different.
Fert
BTW: I have used T-6 in all the diesels I have owned, from the green color motors, to red, to yeller, 6.4, 6.7
Fert
#51
Correct me if I'm wrong here guys but from what I have read the CK-4 oil is not the same oil as the old CJ-4. From what I have read the EPA has forced oil companies to limit or eliminate zinc out of there blend, which was part of most oil brands additive package to help prevent wear. Since ford has not done enough testing to know how that reduction or elimination will affect there Diesel engines they have not approved most CK-4 oils. That is why this is such a mess and confusing as to what to use.
#52
Different oil companies attain the CK-4 standard, differently.
yes, CJ-4 and CK-4 are not the same.
I ran FoMoCo 10w-30 and then switched to T6, CJ-4. Noticed no difference in mpg. My main use is DD with occasional hauling or pulling a relatively light trailer.
#53
I am wondering if changing to T-5 would be about the next best thing and if so how many few miles would you get on an oil change??
Fert
#54
#55
#56
#57
Yea, I just bought 10 gallons of Delo 400 5w40 full synthetic CJ-4 from Wally world....CJ-4. Thats why I started this thread. It's not even orderable online from Walmart anymore, had to go to a couple separate Walmarts in my area to scrounge up 10 gallons.
I used to run Delo 15w40 in my 2005 6.0, and was fine. I completely comfortable running the Delo syn in my 2016, at least for the next year. Hopefully this time next year, this is all sorted out. I'd also have no problem switching to the Valvoline either, its just harder to find around here.
According to the Chevron website, they stop with the CJ-4 next month.
#58
Need to make sure T-5 isn't Ck-4 as well though. I'm not a brand loyal person. I try to get what I think is the best bang for my buck and what I can easily find. If that means going back to FoMoCo or switching to Valvoline, Chevron, Amsoil, Schaefers, or something else so be it.
Last time I was getting ready to try valvoline, but I found Shell with a rebate and on sale... IIRC, it was $15 - $16 a gallon and I bought a bunch of it at that price.
One thing I do want is that Ford says the oil I use conforms to their spec.
#59
