1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Ambinet lighting / cup holder lighting
Old 02-26-2017, 08:13 PM
Berndude's Avatar
Berndude
Berndude is offline
My f250 did not come with any footwell / ambient lighting. is there a factory kit to add it? Also looking for cup holder lighting. Found a place that only does LED lighting for F150's.
Looking at after market kits as well
Suggestions will be helpful!!
Thanks!!!
Old 02-27-2017, 09:58 AM
Mike1's Avatar
Mike1
Mike1 is offline
Foot well? Do you mean under dash lighting for your floorboard? What year and model do you own?
Old 02-28-2017, 11:38 AM
droldsmorland's Avatar
droldsmorland
droldsmorland is offline
Tagging along here. I need more cab lighting. My 11 super cab has near zero cabin lights. It's such a PITA at night. The only thing I have is the two over the rearview.
Old 02-28-2017, 12:50 PM
Mike1's Avatar
Mike1
Mike1 is offline
A cheap way to go for lighting, would be to buy the LED strips with the sticky backing. Mount it under the edge of the dash, or at the bottom of the door panels. These could be tied into the door switches for when you open the doors or into the interior light switch. These lights are bright white and should illuminate the cabin with no problems. I'm sure you can find these on EBay, but here's a link.
https://www.superbrightleds.com/cat/...Fc26wAod9lEAJA
Old 02-28-2017, 06:05 PM
Berndude's Avatar
Berndude
Berndude is offline
Thanks for the info, I looked at that and i have concerns as I have used sticky back units and they did not stay sticky very long on a bar I built
Old 03-01-2017, 07:47 AM
Mike1's Avatar
Mike1
Mike1 is offline
I've never had it fall off myself, but, if that's the case then, go to your local hardware store, buy some small plastic C-channel or box channel, mount that under the dash or wherever, stick the LED's inside of that. If the backing gives out, the edges of the channel will keep it from falling out. Buy a small enough channel that the LED strip fits snug.
Old 03-01-2017, 08:45 PM
Berndude's Avatar
Berndude
Berndude is offline
2016 F250 Platinum Excursion Conversion
Old 03-02-2017, 07:06 AM
AZLugz's Avatar
AZLugz
AZLugz is offline
After you put them on, use exterior clear silicone and put little dots on the edges every couple inches, if the sticky fails, the silicone holds, I do it all the time, works great. Even used this method for Jeep rock lights and they are holding up fine
Matt1966
13
08-08-2019 01:45 PM
ngng
11-12-2008 03:42 PM
timcommon
15
12-05-2006 08:35 AM
thumpper23
12-09-2004 10:19 PM
Quick Reply: Ambinet lighting / cup holder lighting
