1978 - 1996 Big Bronco
Tire rotation
Old 02-26-2017, 07:21 PM
Joecephus's Avatar
Joecephus
Joecephus is offline
Tire rotation
My 1984 Bronco's front tires always wear more on the outside. Usually when I rotate them I move them straight back on the same side. But I was thinking this time I would leave them on the front and switch sides by taking them off the rims and remounting them so that the worn sides (currently the outside) would now be on the inside.The tires would now be on the opposite side of the vehicle and still turning the same direction. Is this a good idea? The tires are Lt 235/75 15's
Old 02-26-2017, 10:04 PM
rla2005's Avatar
rla2005
rla2005 is offline
Received 1,151 Likes on 910 Posts
Check the toe setting. Too much toe-in will wear the outside edge of the tires.
Old 02-26-2017, 10:17 PM
49f68canadian's Avatar
49f68canadian
49f68canadian is offline
Sounds like an alignment concern, either toe or camber is out. Darrell
Old 02-27-2017, 01:17 PM
Joecephus's Avatar
Joecephus
I have had it checked before, but they always say " it's a Ford, that's just the way the tires wear on them. Nothing you can do about it." Looking at it from the front the tires have a very noticeable angle like this / \
Old 02-27-2017, 03:05 PM
Beechkid's Avatar
Beechkid
Beechkid is offline
time to find a new alignment guy!!!!!!!!!!! They use to say the same thing about the Ford Twin I-Beam, but they can be adjusted....it takes a little bit of work versus the slep boys 30 minute special!
Old 03-03-2017, 04:31 PM
moose4x4's Avatar
moose4x4
moose4x4 is offline
How often do you rotate tires? On a 4WD they recommend every 5000 miles or every 3000 with a limited slip diff. They will wear fairly good if you can do them that often. If not they will wear on the outer edge from scuffing when turning.
Old 03-03-2017, 10:54 PM
rla2005's Avatar
rla2005
rla2005 is offline
Sorry I do not have an owners manual handy, but where did that come from? Specifically the limited slip part of your statement.
Old 03-04-2017, 05:30 PM
moose4x4's Avatar
moose4x4
moose4x4 is offline
Not sure of where I picked that info up. After 40 years driving 4WD'S and being a ASE Master Auto and Master Truck mechanic and having been to more training sessions than I can count. Can't remember where I picked that info up.
Old 03-04-2017, 06:21 PM
Conanski's Avatar
Conanski
Conanski is offline
Is that after backing up and parking? If so the suspension tends to do that and will straighten up more when the vehicle is moved forward a few feet. If that isn't after backing up then you could have a number of problems including sacked springs, worn pivot bushings, worn ball joints, or a poor alignment tech. Also if the truck has a lift the lift brackets could be lose or have the wrong springs installed, or the alignment tech neglected to install the necessary camber alignment bushings for the lift kit.
Old 03-06-2017, 08:09 AM
rla2005's Avatar
rla2005
rla2005 is offline
I do not recall ever seeing the 3000 mile rotation interval for a limited-slip equipped vehicle. Learn something new every day
jtorsey91
08-23-2016 11:04 PM
bnovak
Escape & Escape Hybrid
01-03-2011 08:49 PM
royale5
07-11-2006 12:59 PM
SeannyBoy84
09-29-2005 01:51 AM
block0
06-14-2001 02:58 PM
Quick Reply: Tire rotation
