Mirror fell off...
Mirror fell off...
So I got some Gorilla mirror adhesive. That didn't work. Then I bought something else that didn't work. Then I got some PermaTex rear view mirror adhesive. So far it works great!
1) use the supplied wipe to clean the windshield
2) plop a drop of adhesive onto the button
3) hold tight against windshield for 30 seconds
let it cure an hour
4) re-attach the mirror
Mounting button
Done!
That's the stuff!
let it cure an hour
Mounting button
Done!
That's the stuff!
Clean the glass with 0000 steel wool (it doesn't scratch it) and then wipe the glass and button with denatured alcohol of 90% or higher twice and let it dry. Had the same issue you had until an old mechanic told me to use this technique, still hanging in there 3 years later. Since then I have been using steel wool to clean all my auto glass, works great.
Thanks - I'll give it a shot!
I went through the whole mirror falling off thing including scrubbing the glass with acetone and/or alcohol, buffing it with steel wool and using three different brands of adhesive. I finally got it to stick using IC-2000 rubber toughened cyanoacrylate.
It's lasted most of a year now but your mileage will vary.
Michael
Michael
If you have 2 good mirrors on the out side why do you need the 1 inside?
I had 1 fall off the inside and based on them never staying put I just left it off.
I was also pulling a trailer a lot so the one inside was useless.
I also learned to drive in a van with no windows so had to use the outside mirrors so I drive mostly with outside mirrors.
Dave ----
Dave ----
