Looking for exhaust for 400ci
I am building a 400ci and im looking for mufflee sugestions. I have flowtech headers 2.5in collector. I like the sound of flowmaster super 44's but im worried about drone.
here is what ive done to my motor or will have done
750cfm quickfuel slayer carb
ported stock heads i believe 76cc
comp cam high energy 268
TMI 9.4: 1 CR pistons .030 oversize
flowtech headers
weiand aluminum intake
i believe that is it. I want something loud with a noticeable idle and one that you can hear the cam. But i dont want the drone. Im not entirely sure what drone is but i have an idea.
flowtech headers
X2 on the Magnaflows. The 33% better flow through mandrel bends is nice too. My brother took off a FM 44 because it droned badly on his '92, even with a resonator also welded in line. His Magnaflow is much more liveable at cruise rpms. Also have a chambered MF on my Tacoma, and my parents have a straight through on their '89.
Yes, it was welded in. My brothers '92 is a 5.8L Supercab F150 4x4 longbed. He built a full cat-back exhaust for it in 3 inch and had the muffler in the stock location. He used a now discontinued formed tail pipe that he thinks may have contributed to the drone. The pickup hummed at cruising speed inside the cab at a migraine inducing frequency. It will still drone a little at a certain RPM (hence why he suspects that tailpipe), but not at normal cruise speed and not nearly as bad.
Dunno about the claims. I chose them because oval case mufflers run out of room if installed horizontally. .. I see many installed vertically and it just looks like a "work around".
Mandrel bent tubing is a must to achieve full gains.
blueovalbigblock
01-15-2009 09:52 AM
