Tilt on Radiator?
Tilt on Radiator?
Hi all - When I first got my 64 I noticed the radiator in it tilted inward at the top. Its close to the fan on top than on the bottom. Is this correct? I know it is a replacement radiator as it has plugs for AT cooler on bottom, and doubtful I will keep this one, but still wondering if it is supposed to be completely vertical or not. Cheers!
My radiator has a definite tilt rearward as compared with the radiator support but, since the truck is not completely assembled, I can't tell for sure how it aligns with the fan. Since the engine also has an upward tilt going forward, it appears that the fan would be pretty close to parallel with the radiator core. Are your forward mounts o.k., not compressed...and does the fan run true, not wobble??
Red Rascal
05-16-2018 02:13 PM
F-250 restorer
11-01-2014 09:26 AM
2FordTrucks
15
10-20-2013 10:38 AM
DuckRyder
10-18-2003 03:45 AM
