Power Steering Pump
Old 02-25-2017, 09:09 PM
bk117wrench's Avatar
bk117wrench
bk117wrench is offline
Power Steering Pump
I am fixing to change my power steering pump out. When ordering on line there is a pump with a metric fitting and a pump with a standard fitting. Without pulling the fitting and measuring the threads how would I be able to tell? I am going to put a wrench on the fitting in the morning I hope only a standard or metric fits not both.
Old 02-25-2017, 10:10 PM
oldbird1965's Avatar
oldbird1965
oldbird1965 is offline
You have to pull the pulley first before the pump comes off, then you reuse the bolts. That is if I'm understanding your question correctly.
Old 02-26-2017, 09:43 AM
bk117wrench
w/ 1 Inlet Tube in Reservoir;Standard Threaded Fitting;w/ Afterma...
w/ 1 Inlet Tube in Reservoir;Metric Threaded Fitting;w/ Aftermark...
There are the choices, I know I have one inlet tube but the hard line has a fitting on it. I believe that's what their talking about. I could be wrong. I ordered the pully puller set on Amazon yesterday. I gonna fit a wrench on it here shortly I hope that give me an answer.
Old 02-26-2017, 03:14 PM
bk117wrench
18 mm wrench is the only wrench that fits, I will order the pump with the metric fitting.
smle
03-23-2019 02:03 AM
feditmy
01-24-2015 09:15 PM
Alvarez1112
10-17-2010 01:36 PM
blue92f150
06-06-2007 01:34 AM
Quick Reply: Power Steering Pump
