Reman NV271F not working - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old Yesterday, 03:46 PM
hdfe hdfe is offline
hdfe is starting off with a positive reputation.
Picked up a re-manufactured NV271F from a rebuild outfit, which has since gone out of business (!) Bolted it up and hooked up the linkage and.... no lockup between the input shaft and the output shaft. It goes into hi range and low range but no lockup when in park. The output flange always spins no matter what, it always acts like it's in neutral? Any words of wisdom before I yank this dern thing out again? This sucks...
Old Today, 11:27 AM
99f350sd 99f350sd is online now
99f350sd has a good reputation on FTE.99f350sd has a good reputation on FTE.
Wow no fun..I assume you have the linkage all good.
Transmission output shaft is hard to turn by hand Scott1234 1999 to 2016 Super Duty 0 02-20-2017 09:53 PM
5R110 Odd Noise DesertSmoker 1999 to 2016 Super Duty 3 06-20-2016 05:06 PM
2005 Superduty NV271 Fluid type 95bogginbronco 1999 to 2016 Super Duty 4 10-28-2007 05:04 PM
NV4500 swap into f-250 4x4 averagef250 Clutch, Transmission, Differential, Axle & Transfer Case 1 03-31-2006 12:24 AM
overdrive for the c-6 fling 1967 - 1972 F-100 & Larger F-Series Trucks 4 08-08-2005 10:38 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
