Shock absorber angles
56 Ford F-100. Im doing some work that is going to change the pinion angle on rear axel so axel has been stripped of spring perches and shock tubes that had been welded to the axel by pervious owner. I want to use a mount on the bottom of the U-Bolts to mount the bottom of the shock. I removed the stock cross member above the rear axel and replaced it with a new one. My question is the angle of the shock from the bottom to top shock mounts. At what degree is the performance of a shock at its best?
Well, it has to do with getting it as closely in line with wheel travel as possible.
Hours of entertaining and sometimes informative discussion follow in these links. I think the short version is to try to replicate the original mounting angles.
Shocks What Angle & Why??? | The H.A.M.B.
shock absorber angles | The H.A.M.B.
What angle to mount a shock - OFN Forums
Shock mounting tips and installation procedure
I could go on but I think you get it. The last link might be the best.
Schuyles
11-06-2012 10:19 PM
Huntfamily53
04-15-2009 09:14 AM
fatfenders
23
02-01-2005 07:00 AM
fatfenders
08-13-2002 12:14 PM
