2000 F-250 V10
Still trying
the starter i bought was bad so i returned it and put the new one in and it sarted right up ran fine for about 10 min then the battery light came on i shut the truck off tryed to start it and nothing just click one click just like it was doing in the first place so the only thing i havent replaced is the battery so im gonna try that and see what happens?? Any ideas would help and any sugestions about what kind and size battery would be appreciated also
Still trying
I checked the battery it's fine I brought it to a company and they checked it and said that it's in working order truck was running battery light came on I turned it off went to turn it back on and just the click again the same click the same thing it was doing when I first got it and replaced all these parts I have a new alternator good battery new starter new wires from the battery to the starter and from the battery to the alternator all brand new don't know where to go next going to pull out the starter and check it again this is the second starter the first starter I got reconditioned was bad I brought it back and got this starter which is also reconditioned don't understand what is going on??? Running out of things to try or replace??
Again, get a vom and check the batteries when static for a reference voltage. Start the truck and check the voltage at the battery terminals after and expect to see between 13.4-14.2 volts. Not a bad idea to also check the voltage at the large terminal on the alternator, knowing you will see a slight drop in voltage due to wire resistance.
If not, replace the alternator...again.
Thank u i will check the alternator again. I pulled the new,new starter and it is also bad??? So i dnt know if im just haveing really bad luck or what but im gonna buy a new one and seevif that makes a diferance? Also the mark twain comment not sure why that would be directed to me i dnt want to take it to a shop until i have no choice because 80to 100 $ a hour is somthing i cant really aford right now
Also, the tech folder is a great resource as well as the particular "forum" search function.
Some people ask the same questions that have numerous responses to their solution but they never dig in to find those answers.
Some claim that they don't have time and want others to do their homework!
However, Nobody wants to offend others here.
We all hope you find your solution... It will be the alternator or connections from the alternator. Did you do the screwdriver test as advised?
