2012 F150 or 2008 F250 for towing???
Old 02-24-2017, 11:06 AM
Barbs1's Avatar
Barbs1
Barbs1 is offline
Hi All
New to this site. Have a question for you...
I am looking at a work truck and have 2 options... The first is a 2008 F250 crew King Ranch gas and the other is a 2012 F150 Lariat crew gas
so the dealer tells me that the F150 is rated to tow 10,000 pounds - has the max trailer package and air bags installed. I will be using the truck to pull a 7 ton dump trailer approx. once a month over the course of the year.
Both trucks have around 210,000 km on them
Which is better???
Appreciate the input!
Old 02-24-2017, 11:28 AM
Chuck's First Ford's Avatar
Chuck's First Ford
Chuck's First Ford is offline
7 ton is 14,000 pounds.. unless my old math is broken.
that being said.. 7 ton LOADED?????? or just rated 7 ton but you will haul less.
150 = 10,000 maybe.
250 Gas = 12,500 maybe
others might offer better information.
Old 02-24-2017, 11:48 AM
Barbs1's Avatar
Barbs1
Barbs1 is offline
Thanks
rated 7ton and hauling less
would be hauling firewood and the occasional skid steer
My fear with the F150 would be the suspension would not be strong enough for the weight? I am looking for a durable truck
Thanks
Old 02-25-2017, 07:44 AM
1979 Ford's Avatar
1979 Ford
1979 Ford is offline
Go with the F250. I have never liked pulling with a F150. The 250 will have heavier suspension and better suited binders to get it whoa'd.
Old 02-25-2017, 09:56 AM
Barbs1's Avatar
Barbs1
Barbs1 is offline
Thanks. Am leaning that way but was surprised when the guy who is selling the f150 told me how much it can tow
Old 02-25-2017, 10:27 AM
RV_Tech's Avatar
RV_Tech
RV_Tech is offline
Another vote for the 250.
Steve
Old 02-25-2017, 06:58 PM
senix's Avatar
senix
senix is online now
Received 1,416 Likes on 1,011 Posts
F250 will be a lot more stable with the load. I don't recall but I know the receiver is rated for 12.5K.
You might want to upgrade that unless you are doing a gooseneck trailer. Otherwise the Gas F250 will pull the load.
The motor will like to rev but that is fine.
Old 02-27-2017, 09:15 AM
wrvond's Avatar
wrvond
wrvond is offline
If the F150 is an ecobeast, I'd recommend it over the F250. For the other 353 days of the year, the 150 is going to be more comfortable to drive. It also already has airbags to compensate for any sag that might occur when hitched up. My 2012 F250 sagged much worse under the same load than my 2006 F150 did (until I installed bags on the 250).
There are other variables that would affect my choice that aren't mentioned, like 4wd vs. 2wd for example.
But given what you've described, I wouldn't dismiss the F150 out of hand.
Lindenwood
Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
45
12-20-2018 08:51 AM
EB-Larry
2015 - 2020 F150
39
11-21-2017 09:41 PM
bowler304
2015 - 2020 F150
02-27-2016 10:59 PM
mbutts
17
11-09-2011 11:05 AM
rpbf150
2009 - 2014 F150
08-11-2011 05:37 AM
Quick Reply: 2012 F150 or 2008 F250 for towing???
