89 F350 Fun Ton Plow Truck Turbo 460 FiTech
Hi guys, I'm in the process of turning this truck into a do-all beast. Going to try to retain low end torque and fuel economy and use the turbo more as a supercharger to accent the top end.
Budget turbo builds are a lot of fun for me, this will be my 7th turbo build, 2nd turbo build using a FiTech. Here are a couple links from previous builds:
https://www.ford-trucks.com/forums/1...leeper-16.html
https://www.youtube.com/channel/UCh2...b7J6neUhQgEFVA
Here's the truck...
Here's where i'm at now...
http://www.youtube.com/watch?v=aa6Ba...ature=youtu.be
Here's the truck...
460 rebuilt well over 10 years ago, has around 6k miles
D9 block D3 heads D2 4 barrel intake
Economy cam, peak hp about 3500 all done about 4000
Truck mani's 2.5's y into 3" straight pipe
Stock c6
Transfer case???
Dana 60 4.10 gears
Rear end??? 4.10 gears
I will post up some pics of the t case and rear end, see if you guys can tell me what these are.
Stock c6
Transfer case???
Dana 60 4.10 gears
That year used the same transfer case and rear axle no matter what engine it had.
There should be a little round tag on the back of it. Newer transfer cases were 1356, and a little different. I think you could get the 1356 with a pto, is the biggest difference. I don't remember.
If you keep that rear, and the cover is rusted out, look up the 08 aluminum finned diff cover. It's typically only $50 on eBay.
I'm ready to see this project take shape!
Yeah, it may take a little longer to get it right, but it won't look stupid.
And possibly, the other you've seen, got ran into something and bent it.
t case - likely a 1356 in this year. very good design but for potential of pick up tube coming loose, even so i ran one for months on just a cap full of oil by accident
1356 with pto plate: tonners with duals, or sno package, kinda scarce now.
1345 till '87
1356 till early '90's then onward
208: mostly gm and lighter rigs
the bw 4407
then 271 the monster but pump wears thru case
i follow your work closely am always impressed . this fitech is a surprise after your deep commitment to mechanical over electronic builds in the past. the little ford is my favorite! its my go to reference for my rig.
1345 till '87
the bw 4407
It's a shame I already bought the Dorman part. I would have bought this one instead if I had known.
yes to 1356. excellent unit c6 in front of it?
i have easily passed the million mile mark with that combo in a number of trucks, great stuff when gas was under 2/gallon
does it have pto plate?
since i have your ear let ask you something please.
On the 6 project, You mentioned you would be really content with the windsor turbo'ed in a daily driven pick up.
i have a fresh built 6 in a tonner dually4x witth a 5 speed.
using your build design theory can my 6 , how do i ask this,, , can it provide satisfactory, daily, working power, using the remote turbo, the lunatti and so on.
i like how you held timing and manipulated boost- very sensical. for that engine.
the working power part, i cant really put to words rightly.
but i mean a broad, reliable, torque curve and start-every-day reliability.
this should be a p.m. sorry fellas, but his answer is useful to more than just me.
