Pinion Angle
Pinion Angle
I have seen lots of articles on Pinion Angles but always up and down, never side to side. When you are working with an engine/transmission that are installed center to center from front of engine to tailshaft of transmission and connecting to a rear axel with an off set differential, is the side to side pinion angle just as critical as the up and down pinion angle?
The pinion and crank must be parallel in both planes. Best illustration I could find:
http://www.chevytalk.org/fusionbb/fb...drvlnphase.gif
Another one:
Pinion & U-Joint Angles
Another one:
Henrys son
10-19-2008 09:07 AM
therigwelder
05-27-2005 07:24 AM
kopfenjager
03-02-2005 12:42 AM
atccracing
11-02-2004 07:39 AM
