torque specs 223 - Ford Truck Enthusiasts Forums
torque specs 223
Old 08-29-2003, 06:03 PM
mpenni mpenni is offline
mpenni is starting off with a positive reputation.
torque specs 223
is there anywhere i can find all the torque specs for an inline six 223 64 ?
Old 08-30-2003, 07:40 PM
mantta's Avatar
mantta mantta is offline
mantta is gaining momentum as a positive member of FTE.
torque specs 223
I have them somewhere, what ones do you need?
Old 08-30-2003, 08:14 PM
torque specs 223
rod caps,head,oil pump and rocker arm assembly
Old 08-30-2003, 08:27 PM
mantta's Avatar
torque specs 223
Rod caps, 45-50, head, 65-70, oil pump not listed, rocker arm shaft brackets, 45-55. All foot pounds.
Old 08-31-2003, 10:49 AM
torque specs 223
Thanks I realy appreciate it
Old 08-31-2003, 11:44 AM
mantta's Avatar
torque specs 223
The specs I gave you were from a Motors Manual, for a 1955, 223 ci engine.
223 valve lash 78 & 87 Super Cab 1957 - 1960 F100 & Larger F-Series Trucks 1 04-27-2015 07:09 PM
Torque specs 1960 F100 223 oldsenile 1948 - 1956 F1, F100 & Larger F-Series Trucks 1 04-20-2007 08:50 PM
Timing SPECs for 1962 Ford F100 223 cu in John4796 1961 - 1966 F-100 & Larger F-Series Trucks 1 08-03-2003 09:17 AM
223 Inline 6 byates Ford Inline Six, 200, 250, 4.9L / 300 3 03-28-2003 02:44 PM
Torque Specs? FortyFords 1999 to 2016 Super Duty 4 09-17-2002 10:05 PM
Tags
223, engine, ford, head, sequence, spec, specification, specs, torque
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
