07 Expedition ABS & TCS lights
I have a 07 expedition. The ABS & TCS lights are on and some times it does not have power when you take off from a stop. From what I have gathered that it de-fuels or goes into limp mode. It may be a wheel hub/sensor OR the ABS module. I will have to get a OBD2 scanner that reads the ABS codes to see which wheel it could be. Anything else I should look into?
Hooked up to a scanner and turns out its the right, front wheel. Weird thing it doesnt have any power when you first turn the truck on & start moving. After that it doesn't do it until it shuts off and turned back one. Only happens once each time you restart. Looks like a new hub and sensor is needed.
philn
05-16-2008 01:33 AM
