'48 Fuel Line to Frame mounting
Anyone care to share some pics of a safe and logical mounting of my fuel line from the flex hose off the fuel pump down and along the truck frame? BTW..string for demo purposes only..didn't want to bend line just yet before I had a plan.
Ideally I would like to run it along the top of the driver's side bottom frame flange but it appears it may interefere with my clutch pedal
That is real close to the stock routing. I worry about those bolts near where it passes thru the cutout in the crossmember, tho. Are your running board brackets bolted on? I put corrugated plastic wiring loom around my pipe there because of the edges, worried about vibration sawing a hole in them. You might want something even sturdier to shield it.
It would probably be better to wait til your cab is on to make the bend upwards to the pump, maybe you can rig something temporary if you want to run it now? (I think you'll want two bends to follow the shape of the firewall) I can measure how far forward of the crossmember mine bends, but my routing is a little different.
edit -- could you put a cushion clamp under one of the nuts there to hold the line? Or turn those bolts around so just the head is there?
gstirewalt
03-25-2017 07:42 AM
kurtp
11-18-2014 08:52 AM
reed1951
02-09-2014 07:16 PM
