Basic Towing Questions
Next month I am going to do about 1200 miles of towing with my 2017 F250 6.7. Having not used this truck for towing much other than smaller boats, the load will be about 8500 pounds. Not big for the F250 by what it can do, but will be freeway, mountain passes, and all around driving.
1) use tow / haul mode on the column shifter I would think yes?
2) Are there any gears I should lock out or not use such as 6th. My last truck I was told to keep it out of overdrive when towing much of a load, so that is what the tow / haul button did on my old Tundra, it just locked it out of O/D
Thanks for all the info, just wanted to make sure there was no harm in using 6th gear or OD as I call it with a load on it. Have towed a bunch of stuff with other trucks including some wider than legal loads through SF Bay Area traffic, like 9.5 foot wide boats, just getting used to all the cool new stuff on this truck as I am coming out of a 2003 Toyota Tundra so there is a lot that is different. This truck is just so nice, it was one of those after I drove it moments, I sort of found it to be the truck I kept coming back to. Thanks for all the help and info on this board.
I knew this before but I forgot about and the first time I tow with my new truck I got the reminder in grape vine by CHP
hubler13f
08-05-2012 01:50 PM
Rich K
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
06-15-2009 11:26 PM
