2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Headlight issues
Old 02-21-2017, 07:20 PM
quarlow's Avatar
quarlow
quarlow is offline
Headlight issues
I am having trouble with the headlights on my '07 EL.
It started with the passenger side light going out. It was intermittent, so I figured it was about to go out and bought new bulbs. When I replaced that side I noticed the connector was rusty and corroded. I cleaned it out and put the bulb in. It worked fine for a few days then stopped working again. After another deep clean I decided to just replace the connector, I was only getting 8v on the low beam. Brand new connector and still the same issue, same voltage. I checked the fuses (each low beam has its own fuse) and found the fuse didn't look right, the tip was bent like it melted a little and got soft. So I replaced the fuse. Still no lights. I swapped the driver and passenger fuses and both headlights would not work. Then I started the truck and when it was running the driver side will come on. But now it's being intermittent. If I turn on the fog lights it will go off. If I turn off the fog lights it will come on for a second then go off again.
I cannot not find any mention of a low beam relay, or another fuse under the hood. High beam has been fine the whole time, and fog, and tail/turn. It's only the low beam that is giving me trouble.
I think this points to the actual headlight switch in the dash, but am hesitant to buy another part blind. Each step of the way I found an issue, and then tracked it back to another upstream issue. What else can I check before buying a new switch?
I hate electrical issues
Old 02-25-2017, 01:26 PM
quarlow's Avatar
quarlow
quarlow is offline
Update: it's not the headlight switch. I replaced the switch and still have the same issue, but the drivers side lights seems to be fixed now.
Any other ideas?
hayeswg
2009 - 2014 F150
10-23-2023 01:43 PM
maco
2009 - 2014 F150
16
02-12-2017 07:17 AM
grams72
09-22-2009 02:16 AM
adamg101
1997-2006 Expedition & Navigator
11-07-2007 10:38 PM
66f14evr
Electrical Systems/Wiring
11-04-2005 01:50 PM
Quick Reply: Headlight issues
