wants to die in reverse only when warm
I have a 1995 powerstroke that has had the tranny with a new converter replaced in 97. The trouble I am having is when hot it wants to die in reverse. It idles great when hot but it will want to pull down in reverse and if I am at a light and I put it into low sometimes it will pull down then as well. Typical Ford funky shifting revs in first when hot let off and it shifts. FLuid is pink and does not smell burnt, and the level is good hot. Bad IAC???Where is that thing??? Just put a new TRS and wiring Thanks Terry
I made one out of a little aluminum strip, worked perfectly. Just look in here: https://www.ford-trucks.com/forums/1...l#post13059337 It's pictured right after the trans pan maintenance pictures (a little before you hit the post's half point).
95F150RLP
07-07-2017 05:00 PM
Frank250Tank
08-24-2016 07:30 AM
PSU4ME
08-17-2016 03:22 PM
