front windshield trim revisited
i have done this within the last year on my ranger with success, however now i am working on my camper special, i have the gasket on and now ready to install the chrome trim in gasket, any special tricks? use the rope trick? any special tool? can't remember how i did it last time, i remember using alot of swear words working on my ranger windshield
dave
dave
Yeah use rope and pull it from the inside. Also silicone lube works well, or soapy water as lube. I am from Michigan originally, but move away when I was 10. New England is hit or miss for snowmobiling. Lots of rocks so usually its hit (a rock that is) When we get enough to have a nice base it warms up then disappears. Then follow by some more. I miss the days of snow at Thanksgiving and it stays around till St. Patty's Day. Good luck on the windshield and you better get a case of beer and invite some friends to help.
i can get the window in ok, just struggling with getting the chrome trim on the gasket, i did pay a guy to put my ranger window in after putting chrome trim on gasket myself, just can't remember what method i used to install the chrome trim on the gasket, maybe i'll have glassman also install chrome trim, i know the trim has to be installed before installing window
yes, trim goes on after gasket is on window but before install on truck, looking for tip for installing trim on gasket with windshield sitting in my office, everytime i attempt to install trim gasket comes off window, did this last year with a lot of swearing but did accomplish the task, struggling on this one
There is no way, NONE that once the weatherstrip is installed, that the mouldings can then be installed.
on
I used lots of the blue painters tape to hold the gasket on.
I guess you did not get the gasket from DC which comes with instructions.
Using a 3/16' rope then carefully set window into place with rope at the top.
I used two of the Harbor Freight HD metal suction cups to pull on the inside, if you do have a helper. As a side note the plastic suctions cups will pop off ez "junk"
I also used the Harbor Freight nylon little body door tools to aid in pulling the lip over the sheet metal lip and getting the blue tape off.
Not ez when working by yourself placing window in.
Orich
Orich
i have a guy that installed my ranger windshield but i put the gasket on windshield and chrome trim on, then put a couple of ratchet straps to keep in place until he could show up, i think i'm going to have him do the whole thing this time, including the chrome trim, what a pain in the ***, not sure how i did it successfully before
on
Yeah the chrome trim is one big pain in the azz the way it was designed to be installed.
My last windshield with trim, I had Safelite install and have been back twice with the drivers lower corner leaking when it rains. Were having a lot of rain this winter season.
So have a tarp covering the windshield & roof area to keep dry.
I had gotten started to install efi just before it started this dam 5-6 days of rain. for the past month almost completed.
The glass co has a two week back up for any window service an the day, I was suppose to go back for them to fix the leak we had one of the worst rains storms coming in that morning so did not go in wanting my floor wet again. As it took 10 days to dry out before.
I have put 2'' wide painters blue tape on the leak area for when, I can may it back to the glass shop if still raining.
I got the efi install and running but have to get the idle down an every time, I start to fine tune the efi it starts raining.
Orich
Orich
