Ideal compreasion ratio new 390 build
Howdy yall. I got a new motor im building to throw into my 73 F250. Specs are as follows. 390 crank and rods block will proably be 30 over to clean up but hasant been bored yet. Heads are 71 mid risers. Im debating on trying to throw in larger valves or not. Got to have hardened seats thrown in figured while im their ya know? im debating on running flat tops and a thiner head gasket or milling the block or heads to get to bout 10.1. Is this too high for just 91 pump gas? I know it depends on cam and timing but just wanting some of yalls advice. Thanks in advance
Not a simple question.
Depends on:
-Cam selected
-fuel desired
-weight of vehicle, weight of potential load
-gearing
-altitude
-engine cooling ability
-quench
-efficiency of combustion chamber
-intended usage. Big difference between a daily driver, and a fun weekend vehicle.
etc.
Although as 69cj mentioned, the 428cj's were higher compression and ran fine. They also weren't installed in trucks running 2.73 gears, nor hauling 10,000lbs trailers :P It's a whole package thing.
Depends on:
-Cam selected
-fuel desired
-gearing
-altitude
-quench
etc.
If he does much towing he needs a lower rpm higher torque type cam. I hate to use the term RV cam since it's so generic.
8.5 or 9 compression was the low compression regular fuel motors in the '60s.
10 to 12 compression was performance territory.
FE Series Engine Specification Chart
I don't agree, I ran two 390's with 10 to 1 and mild cams (Cam Dynamics and Crane 510's lift and one had a 272* duration, the other a 296*) both ran great with pump gas towing, if anything he could dial back the timing a few degrees to tow. The Cam Dynamics motor was in a 70 F100 and ran fine on regular unleaded. There wasn't anything you could hook to the bumper it wouldn't pull with that motor.
I ran a Cam Dynamics 272 in my 78 F-150 4x4 400 ci engine they only have 216 our at .050 and where considered good 4x4 - towing cams designed for low rpm torque (similar to what some call RV cams).
Years ago several companies made cams that closely copied the 428 CJ cam, these where great DD and towing cams with just a little extra ump.
