1990 E350 starts for 2 sec then dies
Old 02-20-2017, 12:54 PM
tbflyer's Avatar
tbflyer
tbflyer is offline
1990 Ford E-350 with 5.8 L V8 ECC IV/EFI system
Problem:
Doesn't idle. Starts for a few seconds and then dies.
Runs very rough if engine is reved.
Tests:
It is OBD I. I get no DTC codes with KOEO, can't get a reading with KOER.
When I spray starter fluid in "throttle body"... the engine will idle (butterfly closed).
Unplug "idle valve" it will not idle, even with spraying starter fluid into throttle body.
Injector manifold 40 psi, engine off, but key on.
Inline high pressure pump and tank pump are running ok.
I get 10 oz of fuel out of injector maniflod after running pumps for 10 sec.
More tests:
Vacuum tested the "Fuel Pressure Regulator" it's OK
Tested the MAP frequencies with vacuum pump and frequency reading multi-meter.
0"=121 Hz, 5"=107 Hz, 10"=96 Hz, 15"=85 Hz, 20"=73 Hz
NOTE: engine idles and runs smoothly with MAP vacuum disconnected!
Engine vacuum at idle is 18"
Using vacuum tester connected only to MAP, engine idles best at 5"- 7".
If I connect the vacuum line back to the MAP (18" at idle) engine dies.
Is it a defective MAP or are we tricking the ECU and something else is wrong?
Old 02-20-2017, 08:06 PM
Wildman25's Avatar
Wildman25
Wildman25 is offline
Good chance the MAP sensor is shot, would cause this type of running problem.
Check this Link, page 2 has the Vac reading that you should have, or close too, the reading you posted are off by quite a bit.
If the MAP is not sending the correct signal back to the ECU, the ECU will shut the fuel pump down, lack of fuel, no run.
Old 02-21-2017, 06:08 PM
tbflyer's Avatar
tbflyer
tbflyer is offline
MAP sensor was the issue
IT WORKS !!! I replace the MAP sensor and my van is idling and running fine! I was a concerned when I tested the MAP and got a consistent change in frequency with increase in vacuum, but I guess they were the wrong frequencies.
VillaLobos
03-27-2019 09:11 PM
domokdow
06-28-2017 08:23 PM
ewalt98
09-06-2014 05:33 PM
Lead Head
26
11-07-2012 12:59 PM
eyancey
23
09-17-2009 07:43 PM
Quick Reply: 1990 E350 starts for 2 sec then dies
