2008 F150 Starter Relay PCM Ground
My 2008 Ford F150 has a no crank no start issue. The starter relay has constant hot on terminal 30 and hot when cranking on terminal 85. My problem is with the ground side. I have a good ground on terminal 87 but terminal 86 that comes from the PCM is not grounding. I'm assuming it has something to do with the computer (PCM) but I'm not sure. I already replaced the neutral safety switch and I don't think it's the CKP or CMP sensors because the truck runs fine otherwise.
Yeah, that is normal. At least PATS can be eliminated as the cause.
You're not supposed to, you supposed to be measuring the small resistance of the coil of the Bendix and the starter motor windings.
It's not supposed to, pin 86 is supposed to be HOT IN START via the ignition switch and the DTR switch.
Pin 85 is supposed to be grounded when the PCM gives its approval. With pin 86 HOT and pin 85 grounded, the relay is supposed to energize activating the starter motor. Pin 85, if not grounded, would measure HOT if the switches are in order.
If the PCM doesn't ground pin 85 (PATS approval), then pin 85 will read battery voltage in START and the relay won't engage and the engine won't start.
Both logical conditions must be TRUE (key in START and PATS okay) as well as all wiring and switches involved must be okay to start.
jballard81
1997-2006 Expedition & Navigator
05-14-2013 04:05 PM
melvinhil
05-23-2006 07:15 AM
