Barn find!!
Just trying to get it started. I had burnt the clutch and was swapping the T10 to a toploader at the same time. I have upgraded to a duraspark ignition. Put a know working Edelbrock carb on it. I have primed the oil pump after a oil change, oiled all the cylinders but, it doesnt seem to have compression in all the cylinders.
It has a 69 351w with headers so l know l need to check compression but such a pain in the *** to pull plugs.
Bad dizzy
After many backfires and double checking TDC, changing plugs and ignition boxes and a few cans of starting fluid the spark totally stopped. I started checking the electronics and the distributor ended up being faulty. Swapped it with another new one and it fired up. I need to put valve covers back on and hook up the exhaust and go from there.
I am just trying to get it road worthy and weld some new floor pans in her and enjoy it.
Marauder2004
35
12-27-2019 08:25 AM
benbuilder
08-17-2019 07:08 PM
Eteyos
18
04-15-2010 11:01 PM
el conquistador
1983 - 2012 Ranger & B-Series
15
11-21-2004 06:26 PM
