I'm back! 89 f150 project build thread
Only rust I'd a bit of surface on the door.
I've been looking for a truck. Reg cab 2wd manual were the main things I was after. Was looking at 50/60's fords/mercs. But so much body work or not running.
No body work other then paint pretty much, running driving and shot box made me jump on this one
Figure I should make this like a build thread. Will update more as I go.
Sofar
- fixed seized tailgate latch and replaced broken handle.
- neew clutch pedal bushing and re installed clutch safety switch.
- replaced drivers door hinges.
- installed muffler and tail pipe. ( still need hangers yet.)
- picked up the new tires
-found a cab visor locally
Still need to
- install tires on rims
- replace shocks
- replace e-brake cables
- replace rear wheel cylinders
- take for a windshield
- get an inspection
Here's the visor and tires
Sofar
Still need to
- replace shocks
- get an inspection
Sofar
-found a kind visor locally
Still need to
- replace shocks
- get an inspection
%5BURL=http://s1110.photobucket.com/user/Austin_Budd/media/A1E517E5-1A50-4C0F-D5-292B29016F99_zpsho4lylvv.png.html%5D%5BIMG%5Dhttp://i1110.photobucket.com/albums/h456/Austin_Budd/A1E517E5-1A50-4C0F-D5-292B29016F99_zpsho4lylvv.png%5B/IMG%5D%5B/URL%5D
%5BURL=http://s1110.photobucket.com/user/Austin_Budd/media/C3712DC1-6018-4946-8133-53079D38E6F8_zpsicsmo3ee.jpg.html%5D%5BIMG%5Dhttp://i1110.photobucket.com/albums/h456/Austin_Budd/C3712DC1-6018-4946-8133-53079D38E6F8_zpsicsmo3ee.jpg%5B/IMG%5D%5B/URL%5D
Sofar
Still need to
- replace shocks
- get an inspection
Look up under the dash and wiggle the clutch linkage. You'll see where it goes through the fire wall there should be a plastic bushing on the pin where the rod connects. If that bushing is missing that will cause issues. Or of the pin that it clips on is worn out it won't let it push the rod far enough to engage the switch
Dug out the old wheels last night and brought them to wor
Dug out the old wheels last night and brought them to work to wash them.
Coated good with paint stripper and cleaned up some of the rough spots. Looks much better already just need to give a wet sand to the spots I cleaned up and polish them up nice.
Nice ride you got yourself there.
I am interested in what exhaust setup you went with, thinking of changing mine, is that a kit you bought for it? if so what brand?
Too bad you aren't in Australia, Id offer to buy that wheel trim off of you, I got one missing from my truck.
Finished the e-brake cables and wheel cylinders.
All 4 shocks changed.
Threw the old wheels back on it to move it outside to give me more room to work on the aluminium wheels.
All thats left for inspection is a windshield and out the wheels/tires on the truck. And snow melting so I can get it out of my driveway lol.
