Radius arm bushing types
I've been looking at bushings available from different suppliers. Some look to have front and rear bushings that are the same while others have one piece with a longer nipple end. Some are black, red or blue. Is one type better than the others for a stock truck?
Thanks.
john
Thanks.
john
Thanks.
john
Thanks.
john
Suggest review article on Polyurethane vs Rubber radius arm bushings, comes down to a matter of preference. In my cast, the 65 front end alignment was off so recently decided to replaced. Approx. 15 years earlier replaced them with 'rubber' bushings when I upgraded to front disc. brakes but I felt they should have held up better so decided to try the orange flavored Polyurethane variety. Installed with ease and pleased with the fit. Decided to change I-Beam bushing while the front suspension was disassembled.
Suggest make a list of the torque values for the front suspension components for the reassembly, certainly made a significant difference in improving front end alignment!!.
Not sure if it's referred to as the 'axle pivot bushing', or the 'I Beam pivot bushing', it's a single bushing at the swivel point on each I Beam, DC has them listed a P/N C5TZ-3B177-A. Perhaps another member can provide part and item description. If the current bushing appear okay may consider leaving?
Something to be aware of, several types/brands of the aftermarket polyurethane suspension bushings require a special lube when installing, otherwise they can squeak like crazy. Other things to note, Most poly bushings are much stiffer than the original rubber bushings and can noticeably change the ride & handling characteristics of a vehicle, and last but not least, certain types of poly bushings do not react well when encountering petroleum based lubricants, especially ATF and old style power steering fluid.
As Dave mentioned, if you're trying to decide between the original rubber bushings and the newer poly bushings, do lots of research and reading beforehand. Personally I have no problem using poly suspension components in anything except a daily driver, the ride difference (stiffness) is negligible to me.
I just finished my '66 front end today. Fortunately there is no body in it or the job would have been even more difficult. With new bushings, it's quite difficult to get everything back on as I had to pull the radius arms back with a ratchet strap & then everything went in. I went with the Energy Suspension radius arm bushings but on the pivot arms, I had 2 NOS bushings with the shells as the old ones were no good. The left side pivot arm went pretty easy but the right side I had to ream the hell out of the hole as the new bushing wouldn't press in no matter what I did (first a hammer, then my Harbor Freight bottle jack press)
I am so sore I feel like I went a few rounds on the field with Dick Butkus (Chicago Bears linebacker 1965-73) LOL.
stevorino
06-17-2013 06:34 AM
Phil527
07-13-2011 04:04 PM
