Lag on take off
Old 02-19-2017, 08:27 AM
Keith R. Kufner's Avatar
Keith R. Kufner
Keith R. Kufner is offline
Lag on take off
Hi All, My 07 FX2 has a lag when I push the gas. If I had to guess I would say my Injectors are going bad. I push the gas peddle and it take 10 seconds or so for the truck to go. My truck does not shake it idles fine. It just happens when I take off or when I let my foot off the pedal when driving. It's like it's taking a few seconds for fuel to fill the engine and then it runs fine. My check engine light is NOT on.
Old 02-22-2017, 04:51 PM
enriched&beyound's Avatar
enriched&beyound
enriched&beyound is offline
Start simple....change the air filter and the fuel filter. Unless these things have been done already?? Also Check the transmission for correct fluid level.
if the fore mentioned are good....then you may have a brake hanging up (front or rear), or you might have a wheel bearing going bad??
excursion22
11-21-2010 04:38 PM
ttexastim
02-27-2009 02:35 PM
tsc7690
1997 - 2003 F150
05-03-2006 01:38 PM
jnye6625
03-02-2005 03:22 PM
Sleepy Paul
07-26-2003 02:25 PM
Quick Reply: Lag on take off
