What is this rocker arm part called? 1976 Ford Courier (Mazda VB SOHC Egnine)
Old 02-18-2017, 09:38 PM
1976courier's Avatar
1976courier
1976courier is offline
I am working on getting a 1976 Ford Courier up and running. One of the rocker arms is missing this part (circled in yellow in the following pictures), and that rocker arm destroyed the camshaft and cannot be adjusted without this missing part. I ordered new rocker arms, and they are also missing this part. The part is the nut that goes on the end of the bolt that runs through the rocker arm.
In the first image, the rocker arm on the right has this part (circled in yellow). The rocker arm on the left does not have this part.
https://goo.gl/photos/FrDPvfCcmax1BY4f8
This is another view of the missing part.
https://goo.gl/photos/Xk69kkppoeQyXyY7A
Old 02-18-2017, 11:25 PM
1976courier
I think that this has been solved. It's a rocker arm adjusting screw valve. D27Z-6549-C I just ordered some for about $2 each.
Old 03-11-2017, 09:39 PM
sawmaned's Avatar
sawmaned
sawmaned is offline
parts
good you found some,if your in need of some parts i have a 72,78,80 i am parting out,
Old 03-11-2017, 09:42 PM
1976courier
I might take you up on the offer. Where are you located, and do you have any photos of the 1972? Thanks!
Old 03-11-2017, 10:48 PM
sawmaned's Avatar
sawmaned
sawmaned is offline
far northern ca,mostly just parts,motor parts,transmissions,rear ends,ect
Thinlizzy13
10-11-2015 03:47 PM
Flip4ford
Kansas Chapter
11-05-2013 07:51 AM
edo379
13
02-25-2008 01:28 PM
desertdave35
12-02-2006 07:19 PM
WALJON
12-24-2003 03:25 PM
Quick Reply: What is this rocker arm part called? 1976 Ford Courier (Mazda VB SOHC Egnine)
