Shifting issue on my 1972 C700 - Ford Truck Enthusiasts Forums
Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Old 02-18-2017, 10:29 PM
garyscc garyscc is offline
garyscc is starting off with a positive reputation.
Hi all, i just bought a '72 C700. its pretty cool to me since it has a fabco 4x4 conversion. I'm currently trying to figure out why I can't find reverse. It seems to go into all the forward gears fine, but i can't find reverse. I'm thinking the linkage could be the problem. Right now its stuck in mud. So, i'd like to move it a few feet onto a hard surface. Is there a way for me to disconnect the linkage and manually shift the transmission into reverse? It is my understanding it has the clark 5 speed transmission. The black shifter **** shows reverse lower left, 1st upper right. I can't get the shifter to move to left any more. So its possible i'm only getting to 2nd and 3rd. Any help on this is appreciated! gary
Old 02-19-2017, 09:02 AM
Tenwheeler Tenwheeler is offline
Tenwheeler is starting off with a positive reputation.
Remove the shift lever from the top of the transmission. Look in the hole to see if all the shift rails a lined up in neutral. If not make if so and put the stick back in.
Old 02-19-2017, 02:25 PM
firebirdparts's Avatar
firebirdparts firebirdparts is offline
firebirdparts is starting off with a positive reputation.
On some clarks reverse is far right and up, and second/third is as far left as they go. The fact that you would never expect that suggests that the transmission may be fine. That is something to hope for anyway. If you've had it in low gear then maybe that's not it. You could at least try lower right.
if there is any kind of reverse lockout, that would produce the same problem. I never saw one that way.
Old 02-19-2017, 02:51 PM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Old 02-19-2017, 08:28 PM
I don't think i can get access to the top of the transmission. This is a dump truck - but the hydraulics for the dump are missing - so I can't move the flatbed. Is there another way to access it?
I think maybe you are right about the shift pattern. Its frustrating since the shifter **** shows reverse bottom left. I usually rely on the *****. So, for a '72 Clark is there a certain shift pattern I can assume? I tried most locations to left and right and everything seems to go forward at different efforts.
I had a tow truck pull it out of the mud. so for now I'm not in a hurry, but I definately want to get this cool truck road ready.
Old 02-19-2017, 08:36 PM
i noticed the image says before a certain vin number. my vin is C70EVN33292. So is that image still the right one for my application?
Old 02-19-2017, 09:04 PM
Quote:
Originally Posted by garyscc View Post
i noticed the image says before serial number M60,001.
My vin is C70EVN33292. So is that image still the right one for my application?
It is now...
Old 02-19-2017, 09:14 PM
I don't know. I looked under the cab at what I thought the shifter - it looked like a couple of u-joints. I don't see u-joints in that photo. I appreciate all the help.
Old 02-19-2017, 09:20 PM
I believe you're looking at the steering shaft, as it contains two u-joints.
See 3815 in pic:
Old 02-20-2017, 02:14 PM
I think you are right. I was looking at the steering joint. Once the rain stops here i'll go out and look at the correct linkage. thanks!
Old 02-20-2017, 09:42 PM
I gave it another try to shift it. This time I put some tape on the dashboard and on the bench seat, and each time I was able to put it into a gear I marked either the dashboard or the seat. Based on this, I was able to get into (4) gears only. I'm assuming I found 2, 3, 4 and 5. I tried slamming it to the left a few times and then up, and when I let out the clutch it made a grinding sound. The previous owner did mention to me (and showed me) that the flex hose for the clutch slave cylinder was leaking. I did visually see the leak. Is it possible that if there is air in the line or not enough hydraulic fluid that I could not be able to shift into 1 and R ?
On a side note, i checked the Letter L shown on the data plate for transmission. According to the demo pdf for '72 ford trucks L stands for an Allison AT540. And, one of the large factory stickers on the dashboard says AT540 - and it gives an explanation for each shifted gear. But, since I know the vehicle has a clutch, and a manual shifter I can only assume that when FABCO did the 4x4 conversion they must have swapped in the Clark 5 speed. Does that make sense?
1974 C600 Transmission Swap and Shifter WONT WORK! William Cabot Boyd Large Truck 17 09-06-2016 08:37 PM
Transmission Issues cdouglas75 1973 - 1979 F-100 & Larger F-Series Trucks 7 06-22-2016 09:35 PM
U0101 DTC issue houzer 6.4L Power Stroke Diesel 7 03-19-2016 10:24 AM
1978 E150 w/ 4 speed manual trans won't shift into reverse Help? (4th = overdrive) JRWooden 1968-2013 Full Size Vans 18 10-24-2015 12:15 PM
1968 C600 Shifter Problem 55 2nd series Large Truck 9 07-23-2015 10:41 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
