Cam phasers? Added video of noise.
Old 02-18-2017, 11:43 AM
5280's Avatar
5280
5280 is offline
2008 5.4l Expedition, 160k miles. Intermittent rough idle, runs better under load, initially did not throw any codes, now I get P0300, P2195, P2197, weird noise at idle once warm, hard to describe, sounds rotational, but not consistent knock, but not like a rod.
Old 02-18-2017, 11:56 AM
5280's Avatar
5280
5280 is offline
Old 02-18-2017, 08:28 PM
Pocketlint's Avatar
Pocketlint
Pocketlint is offline
When I am watching the video it almost looks like it is coming from the back of the fan, if you look at your video and watch where the back of the fan as it is turning, it almost looks like there is a skip in the revolution as the fan goes around.
Have a look at that first. There seems to be a skip, I dont think that is cam phaser noise, I just did cam phasers on my 06 F250 and it it didnt sound like the sound your hearing
Old 02-19-2017, 09:22 AM
5280's Avatar
5280
5280 is offline
Thanks for the response.
The truck has a hard miss at idle, I think the fan skip on the video is while it is missing. It sounds like the noise is coming from the top of the engine, though I can't say for sure. I will check it out a little closer today, keeping in mind your thoughts on the fan.
Old 02-19-2017, 05:29 PM
Pocketlint's Avatar
Pocketlint
Well I know when I did the phasers on one of my trucks, it almost sounded like lifter noise like a tick tick tick sound and was more to one side of the negine and became more prevalent as the engine got hot, when you stepped on the pedal and held it above 2500 RPMS of course the tick went away but as it dropped down to normal idle the tick came back.
Just some info that led me to believe it was phasers on my truck
Old 02-19-2017, 10:50 PM
07F150Lariat5.4's Avatar
07F150Lariat5.4
07F150Lariat5.4 is offline
Could be the VCT solenoids. They're known for sticking with high mileage. Worst case scenario; you'll need a complete timing chain component replacement.
Old 02-22-2017, 05:00 PM
enriched&beyound's Avatar
enriched&beyound
enriched&beyound is offline
Agree it is the VCT solenoids and you lost one side of your timing chain tensioner guides...the timing chain is slapping the cover. You'll need to check for debris in the oil pan as well and a new oil pump, timing chains tensioners, VCT solenoids, phasers, the whole shaa-bang. with the oil pump make sure you get a revised oil pump with a heavier back plate.
I would not drive this any more then absolutely necessary!
Old 03-05-2017, 06:34 PM
Justino Sanchez's Avatar
Justino Sanchez
Justino Sanchez is offline
Hi there guys, New to ford recently purchased a expedition with 170k miles on it replaced the manifold and now it's idling rough also giving me poor gas mileage I want to say it's sluggish as well. Don't know what could be the case here. Also started noticing a stutter with the ride while in park or while at a stop sign.
Old 03-05-2017, 09:53 PM
z31freakify's Avatar
z31freakify
z31freakify is online now
Received 1,188 Likes on 816 Posts
Welcome to FTE!
You might want to start your own thread so you can get more feed back on your problem. You can give us more info so we can help sort out your problem.
Ok to answer your question seems like you have a miss fire, and from your info I assume you had coolant go into one of the spark plug holes causing a miss fire. Also bad COP (coil over plug) boots, moisture intrusion, a bad spark plug, bad connection or a bad COP can cause a miss fire. If you have an AutoZone near you tell them to scan it for you and give us the codes so we can pinpoint what's the real problem.
z31freakify
Welcome to FTE!
Old 03-06-2017, 08:16 AM
Justino Sanchez
I'll start with the tune up first it's hard to find a good ford mechanic other than the dealers here in ny.
girlsluvtrucks
2015 - 2020 F150
02-18-2018 04:47 PM
spunout
06-03-2010 01:02 PM
ecotree
07-01-2008 06:44 AM
devilinuniform
05-21-2002 01:23 PM
Quick Reply: Cam phasers? Added video of noise.
