300 miles from home, problems ...
#31
Bosch is the manufacturer of the OEM pump - they won the bid. So... if it is a Bosch pump spec'd for a Ford Superduty with the 7.3L - then it's most likely OEM.
The high-volume traffic factor outweighs the brand factor. I'm not going to imply Joe is better at maintaining the integrity of his tank than Shell does, but when the quality of the delivery system is equal - a significant volume difference will draw me in. Think Fred Meyer diesel near town with a discount and 4 pumps vs. Art's Shell with the single diesel pump out back.
#32
Sulfur may not in its molecular form be a natural lubricant. But it was used as an extreme pressure additive for a long time. Under pressure and heat it forms sulfides many of which are excellent lubricants. Specifically in an injection pump or the intensifier pistons of our injectors it will form an iron sulfide barrier between piston and barrel which provides excellent lubrication and prevents galling.
In short the low pressure lubricity of the fuel is probably unaffected by sulfur. But the extreme pressure lubricity of sulfur isn't matched by almost anything else soluble in fuel. Which incidentally coincides well with your second point. The other good ep additives are not as soluble in fuel oil, hence why they can and do fall out of suspension. Leaving you with crap fuel.
The sulfur is a great lubricant. If you don't believe me ask any old timer machinist how bad they miss the days when they could buy high sulfur cutting oil. Many of them still have a stash for personal use. I have some saved for my hard to replace HSS tooling. But I wouldn't waste it on anything carbide.
#34
...Sulfur may not in its molecular form be a natural lubricant. But it was used as an extreme pressure additive for a long time. Under pressure and heat it forms sulfides many of which are excellent lubricants. Specifically in an injection pump or the intensifier pistons of our injectors it will form an iron sulfide barrier between piston and barrel which provides excellent lubrication and prevents galling...
#35
#36
No problem. If you google sulfur as a diesel lubricant the first 700 pages that pop up will be EPA, Sierra club, environmental stewardship type pages celebrating its near elimination in fuel. I remember seeing a lot of literature around the time of the switch to usld stating the half truth that sulfur is not a lubricant. And we won't miss it. I even saw studies that proved that it wasn't a good lubricant. However most of it was at best negligent if not bad science, all of them focused on sulfur in low pressure wear tests. Where it doesn't excel. But this is the kind of results based bad science we get these days.
I remember it vividly because one of my professors used the sulfur as a lubricant argument as a test case to prove that without objectivity science is meaningless.
#37
#38
#39
From my experience, without physically removing and resealing the window, you'll never get a water tight condition.
Mine, would drip from the sheet metal screw from the ebrake. It was then, I traveled upword to the gem, to find the puddling. Once new window was installed(had a crack) was when water stopped penetrating
#40
10k miles on the fuel filter isn't much, but it is a cheap and fast thing to replace it, just in case. I don't know if it is true or not, but I have been told that fuel filters will need to be replaced much more often when temps get below 32F if no fuel additives are used.
#41
The wipers don't make a difference. I did change out the CPS for the purple one that Clay sells. Nice snappy throttle response, compared to my old worn out one, but it did not fix my problem.
#43
Not yet, been too busy at the ranch. I am planning to do it tomorrow, when the pump comes in. Should I use a compressor, or just my lungs ? This still seems like a fuel delivery problem. Feels like maybe air in the system or fuel starvation. Not sure. I know what a bad Injector in a big truck feels like, and this isn't that, but idk what a bad Injector in a powerstroke feels like. It's just a mild stutter almost like a miss.
#44
#45
