Steering wheel horn & rear slider window questions
I take that to mean the horn pads from the 80-86 range are all the same in that regard, correct?
The rear sliders, I came across a set that were in good shape in a later ('88 maybe?) but couldn't see how to remove them!
Is there an easy method like lift and pop them out or do I have to know a quick trick for that?
That was how I was thinking - easy out on the windows = easy in to the truck. Well, it is a junk yard so I guess I have some latitude in the learning experience so to speak.
Dave - that's a thought other than I'm 200+ miles from with a 2 seat drop top. Too cold right now for that. I have taken a front bumper home with that car tho' it was warmer outside.
1973/96 F100/350; 1997 F250 H/D & F350 sliding back window interchanges. The glass is thinner on 1980/97's, the 1973/79 weatherstrip won't work on 1980/97.
I have a 1994 rear slider on my 1985 F150. It is a direct fit with no modifications needed.
The only difference is the 1994 - 1996(7) sliders have one-piece solid black gasket (I switched that out for the earlier gasket with the chrome lockstrip) and the 1994 - 1996(7) slider has a MUCH better window latch/handle. Unlike the earlier sliders that have a cheap plastic latch that will break if you pull on it or use it as a handle, the 1994 - 1996(7) slider has two metal pieces that click together to lock the window and and you *can* use it as handle.
johnve
09-27-2007 05:44 PM
gonzales7727
07-10-2005 10:50 PM
