Front brake job just completed: 2013 FX4
Just finished replacing pads and rotors on '13 FX4 w/ 31k miles.
The usual: warped, pulsating rotors.
There are many options re: pads and rotors, I wanted to keep it all Ford. Based on my experience with past F150's, I knew Ford had upgraded parts available.
I used the following:
Rotors: p/n BRR-227 Motorcraft
Pads: p/n BRSD-1414 Motorcraft
The rotors are improved in 2 key areas: there are more cooling vanes, and there is more material at the mounting flange and where the flange meets the braking surfaces. It's this weaker area on the OEM rotors that causes the rotors to have runout, resulting in chatter. That's why 'turning' the rotors is a stop-gap.
These improved rotors have shown well over 70k of service for me before.
As the part number suggests, the pads are "Super Duty" (not to be confused with the Super Duty truck line). The pads have a better compound than the OEM pads, are quiet, and have better grip. They also produce much less brake dust. The pads also come with new "slippers", the part that the ends of the pads ride on. These can get worn, causing the pads to bind slightly.
Rotors: $70 ea. from Amazon
Pads: $60 from Amazon
Hope this helps.
Hope this helps.
Just walking in asking for a brake service on an F150, I'd say you'd get the standard Motorcraft replacement pads just about every time.
The Motorcraft pads/rotors will most likely be different than the OEM installed parts anyway. I know they were in the past and the factory oil filter and the Motorcraft oil filter still have different manufacturers.
You can ask for the severe duty pads. I try to make sure the customer is aware of the severe duty option on F250/350's since we see some come in with the brakes wore out in 30-40k miles due to towing.
https://www.carid.com/motorcraft/sup...FUtNfgodUdkMtg
Ford's description, not mine.
The FoMoCo p/n is: 8L3Z-2V001-B.
Our parts catalog at the dealership shows them as severe duty. There were also severe duty pads available for Crown Vic's that we put on police package cars.
I'm not familiar with what Motorcraft or their distributors call them but if you walk into a dealership and ask for Superduty pads they're probably going ask you if you drive an F250 or F350.
I talked to my dealers parts department yesterday. The guy said that they use a lot of the "Super Duty" pads on the Superduty trucks. They don't stock the Super Duty pads for the F150 but can get them in a few hours. He asked me to call the day before I bring the truck in if I want the SD break pads. That's what I plan to do. Thanks for all the information that has been shared here.
