302 injectors
Old 02-17-2017, 03:49 PM
Nathan511's Avatar
Nathan511
Nathan511 is offline
302 injectors
i order new injectors for my 95 f150 with the 302. They are remand injectors. I opened the box to find that it seems they shipped me 2 different types of injectors. 2 of them have a black tip and the they appear to be the same as stock. The other 6 have a yellow tip and seem to have some sort of pin where the ports should be. I have posted pictures to show what I'm talking about. My question is do I need to return the yellow tip ones cuz they sent the wrong ones? Or are both types of injectors fine to use together in my truck?
Old 02-17-2017, 05:11 PM
rla2005's Avatar
rla2005
rla2005 is online now
Received 1,164 Likes on 919 Posts
They sent you a mix of the older and newer style injectors, single hole versus 4 hole. The latter are supposedly a little more efficient. Regardless, I would not mix-n-match. For remans. I highly suggest the single hole version.
I believe the early version are referred to as EV1 and the later version w/4 holes is EV6.
Old 02-17-2017, 09:13 PM
Conanski's Avatar
Conanski
Conanski is offline
The 4 hole injectors are prone to sticking open, so despite the fact they atomize fuel better than the early pintle style they're not worth the hastle IMO.
Old 02-18-2017, 09:35 PM
Nathan511's Avatar
Nathan511
alright thank you man appriate it
Old 02-21-2017, 08:24 AM
gman97005's Avatar
gman97005
gman97005 is offline
Who did you purchase the Reman injectors from ?
I would not like to have same thing happen to me or others..
Old 07-12-2018, 10:31 AM
jeffreyclay's Avatar
jeffreyclay
jeffreyclay is offline
Seeing how I have a leaking injector that's good to know. I plan to replace them all real soon. Conanski, do you have a preferred brand? I'll be looking for remanufactured to save money but I've read good things on the Denso injectors. I'm driving a stock 94 E150 with a 302.
Muddy74Ford
04-17-2014 02:06 AM
milman
12-03-2012 08:26 AM
takotruckin
08-09-2010 02:33 PM
mauicruza
06-02-2005 02:15 AM
ferguson777
17
03-23-2004 04:49 PM
Quick Reply: 302 injectors
