1966 Ford F100 6 Cylinder
I wanted to get rid of the mess that I created when I occasionally spilled the oil. I hogged out the top of the oil-bath housing, got rid of all that "fur", ground smooth all the edges, cleaned it up, and put in a complete aftermarket air cleaner - bottom, paper element and top. I put the chromed tin top on upside down so the original housing top doesn't rock.
It looks exactly as it did before the change. I used a 10 or 10.5" diameter Edelbrock, - mine is a V8 and I think it's larger than you need - but I'm sure there's one that will fit yours.
Eric .
Edit: The reason I spilled it so often is that I agree with Tedster...
Eric .
On rare occasion, I've seen a flash of fire come back up through a carb when starting or shutting down. No filter of any kind might let a little fire escape. A "little" fire is probably okay...right ?
Speaking from experience, the fire hazard with an oil bath filter is the lack of maintenance. When you change the oil in the filter, make sure that you clean the canister. After driving mine for the first time, and the engine was good and warmed up it backfired through the carb, it caught the build up of old oil around the bottom on fire. The trick is to keep it clean.
Nobby
12-04-2011 11:42 PM
pdwhitt
23
12-01-2004 08:47 PM
bob-63-292
05-22-2003 07:56 AM
orygunmike
10-16-2002 09:27 PM
