Do either of you have pictures of the Cali Off-Road's on the truck? Do the rears poke out beyond the fender and do the fronts rub at all? I assume you both have a level kit installed in the front.
Thanks, it looks like the spacing in the rear is about half of stock maybe a bit more. What gears do you have on your truck and do you happen to have a full side shot including fronts?
Thanks that looks good. Wondering what RPM a 4.30 would run those at 75MPH. Also noticed that for some reason the load rating on the inner rear wheel is only 2500 vs 3200 for the outers. I would of thought they could have put more material on the inner to increase its capacity.
4.30 gear would only be for a gas truck not a diesel in a 350drw
Or a 450
I think your referring to 4.10 gearing
