:-huh Darn it....!!! - Ford Truck Enthusiasts Forums
Old 02-15-2017, 05:02 PM
T Yudell's Avatar
T Yudell T Yudell is offline
T Yudell is starting off with a positive reputation.
Cool :-huh Darn it....!!!
I messed up and put my power steering pulley on backward....was in a rush...wanted to know of a replacement part number or comparable one that will fit my power steering pump... single v-belt pulley for my 89' F-350 7.3 IDI...anyone?
Old 02-15-2017, 10:42 PM
genscripter's Avatar
genscripter genscripter is offline
genscripter is starting off with a positive reputation.
hmmm. I haven't pulled my PS pulley in years, but I thought it was just slid on with a compression bolt ...
Can't you just pull it off and reinstall it again?
Old 02-15-2017, 10:43 PM
You should do it now, before it gets all rusted and set in place. The sooner the better.
Old 02-16-2017, 07:13 AM
T Yudell's Avatar
Need to use a puller...but the lip to pull it is on the inside of the steering pump shaft...SOL
Old 02-16-2017, 07:57 AM
Herb Brooks Herb Brooks is offline
Herb Brooks is starting off with a positive reputation.
I can see what your problem is, but can't recall if there is room to drill a couple of holes adjacent to the shaft and use a bar puller to remove. There is always the cutoff tool route. If the alignment is ok I would maybe run it. Probly not would depend on how quick I needed the truck.
Old 02-16-2017, 10:38 AM
Can you take it to a shop? I remember when I had my Alternator pulley removed, I took it to a nearby shop and they did the job for really cheap. Something like $20 and it was all done in a few minutes.
Old 02-17-2017, 02:17 AM
Fixnstuff Fixnstuff is offline
Fixnstuff is starting off with a positive reputation.
Example: A shop that works on equipment trucks, forklifts etc. should be able to set that up in a small hydraulic press quite easily and get it right off. Therefore I think that any good automotive or truck shop should have enough adaptors and accessories for their hydraulic press to figure that out in a few minutes and get it off. If they can't take it to a better equipped or older shop with more experience.
[EDIT to add] Don't let anyone try to pull it off by the edges with a gear puller as it will bend and ruin it.
If it does get ruined in getting it off- no big deal: MOST of the older Ford trucks in the wrecking yards use the same power steering pumps and pulleys. I needed a power steering MOUNTING BRACKET so I used my power steering pulley remover kit/installer to remove the pulley right in the wrecking yard. You can BORROW a remover kit from the parts stores as a LOANER, place deposit and you get it back when you return the tool. Unethical? It's kinda OK, if you normally buy parts at that store.
power steering pulley installation tommyblack 2004 - 2008 F150 2 01-08-2015 12:02 PM
Power Steering Pulley Mike-fire32 Large Truck 1 06-05-2013 09:58 AM
Removing backwards power steering pulley Marky48170 Brakes, Steering, Suspension, Tires, & Wheels 1 07-29-2012 09:00 AM
Power steering pump pulley bent?.... '78F250351m 1973 - 1979 F-100 & Larger F-Series Trucks 16 07-11-2011 02:51 PM
Power steering pulley removal cabloom300 1973 - 1979 F-100 & Larger F-Series Trucks 8 03-11-2011 01:24 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
