88 7.3 idi knocking while rpms low - Ford Truck Enthusiasts Forums
Old 02-14-2017, 09:28 PM
Poondaddy420 Poondaddy420 is offline
Poondaddy420 is starting off with a positive reputation.
Hi my names chandler. I. Bought a 88 f250 with a 7.3 idi over a year ago. Not sure how many miles are on it due to the odometer resetting every 100000 miles. Its at 60000 now so id guess 260000. But anyways when i start the truck it will idle fine for a minute or two then it will start knocking. Sounds like its running out of oil. But when i give it a little gas it goes away. Which makes me think its the oil pump. It runs like new when im driving but as soon as i stop at a stop light if im not keeping the rpms up it starts its shinnanigans. If anyone has any advice on how to fix thos it would be much appreciated because im trying to restore the truck and keep her running forever. And its a 5 speed. The clutch is also really hard to push im used to it now but my wife cant drive it because of thay thanks
Old 02-14-2017, 09:49 PM
Macrobb's Avatar
Macrobb Macrobb is offline
Macrobb is gaining momentum as a positive member of FTE.
Give us a video.
I'm thinking clutch here. A failing dual mass flywheel can make a lot of noise(the springs that hold the two pieces together and 'cushion' the diesel pulses can fail).
If it's an upgraded single mass flywheel, check that the shift fork isn't rattling around.
Old 02-14-2017, 09:55 PM
U could be right. It seems to do it less while i have the clutch pushed in i will take a video tomorrow on my way to work. Cam i post a video to this site or doni youtube it amd put up a link
Old 02-15-2017, 04:53 PM
hairyboxnoogle's Avatar
hairyboxnoogle hairyboxnoogle is offline
hairyboxnoogle is gaining momentum as a positive member of FTE.hairyboxnoogle is gaining momentum as a positive member of FTE.
I agree, sounds like a DMF on its way out.
Old 02-17-2017, 03:37 AM
Fixnstuff Fixnstuff is offline
Fixnstuff is starting off with a positive reputation.
Quote:
Most people upload to Youtube and then copy the URL and paste it into your message text window OR click the 'INSERT LINK' button above the text window in your post, a small pop-up window comes up and paste the url into that.
Either way I think this will result in the Youtube video being playable right here in your post, rather than following a pasted url to the youtube site.
I think I just pasted the url right into the message and the video was playable right from here and could be enlarged to full screen, which means that a Youtube url is automatically "embedded"
If that is how it works that's a nice feature of the forum software.
I was just noticing what a HUGE and sophisticated site this is! It's very Impressive!! One of these days when I get some money (Which I WILL!) I'll become a supporting member.
Old 02-17-2017, 11:05 PM
speedwrench72's Avatar
speedwrench72 speedwrench72 is offline
speedwrench72 is starting off with a positive reputation.
before attempting to adjust the clutch peddle one must under stand how it all relates, if not properly adjusted it can be more difficult to press (release) the peddle, most have a spring under the dash the helps one to press the peddle, if this is broken peddle effort may be increased, carfuly inspect all components, before spending money good luck.
Acceleration problem s Big_Z88 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 3 04-05-2016 08:57 AM
7.3 IDI engine knock (bad injectors???) bozone802 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 26 03-21-2016 01:13 PM
engine knock problem FxRiZBeAsTLy 1973 - 1979 F-100 & Larger F-Series Trucks 7 12-11-2010 10:45 AM
no rpms on gauges on a 93 7.3 idi Coalroller Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 7 01-02-2010 09:45 AM
Lugging a 7.3w/6Spd?!? Fordbronco69 1999 - 2003 7.3L Power Stroke Diesel 8 01-13-2006 08:12 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
