C/E Light on. Purge Canister Solenoid Code - Ford Truck Enthusiasts Forums
Old 02-14-2017, 09:21 PM
MonroeHandyMan's Avatar
MonroeHandyMan MonroeHandyMan is offline
MonroeHandyMan is starting off with a positive reputation.
Hey guys,
Been a member here for years. Had a bunch of F250's and a nice F150. Now I have two Broncos. Always had great responses and help from this site.
I just bought a 96 Bronco xlt 5.0 last week. It runs like a champ, is super clean. I searched the forums and didn't find what I was looking for...
I have two issues though:
1. One simple one is the o/d light is blinking and shuts off as I drive. No tranny issues at all, shifts nice.
2. I have a Check Engine light on. I pulled the code and only got one. It was a Purge code. I went to Ford and bought a new gas cap hoping it might be that. It wasn't as I reset and it came back on after maybe 4 miles. I bought the new black plastic purge solenoid canister for $90 from Advanced Auto, changed it out and found one small hard vacuum line going to the bottom of it was broken, so I fixed that and put the new purge canister solenoid on. I pulled the positive cable off the battery to reset the computer. I drove to Tractor supply which is about 5 miles from my house, shut the truck off, came back out, turned the truck on and the light came back. I need help with this one. I want to get the truck inspected as a I have a 10 day temp tag for inspection. This is the only code the truck comes up with.
Thanks in advance,
Anthony
Old 02-16-2017, 06:55 AM
I pulled the codes again and got a p0443 evaporative emission system purge control valve circuit and I got a p1351 ignition diagnostic monitor input circuit.
I tried changing out the purge solenoid and the check engine light came on about 10 min after I cleared it. I am going to swap out my egr valve today to see if that's the culprit as mine looks like its rusted pretty bad.
Old 02-23-2017, 08:54 AM
rla2005's Avatar
rla2005 rla2005 is offline
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
Quote:
I have seen this before. Sometimes you may get weird transmission issues too. If you did replace the Vapor Management Valve (VMV) and still get the same error I suggest you trace the wires to ensure there are no open circuits back to the computer. If that checks out then it's usually a bad computer (PCM). I have run across about a half dozen of these scenarios over the last 5-6 years on this vintage F150/Bronco.
Just to be clear the 1996 F150/Bronco uses a Vapor Management Valve to control fuel vapors. It's not the same as the older Canister Purge (CANP) solenoid.
What color Ignition Control Module (ICM) do you have on the truck? Black or Gray.
Why? none of those codes indicate an EGR issue.
2010 Ford Escape Purge Valve Canister? kd5151 Escape & Escape Hybrid 21 10-30-2014 11:30 PM
'91 F-150 4.9L idle problem enrgizerbunny Ford Inline Six, 200, 250, 4.9L / 300 9 12-06-2013 04:42 AM
P0433 Fault Code pablocruz69 1997-2006 Expedition & Navigator 11 08-13-2010 12:50 PM
Codes 565 Canister Purge, 172 O2 Sensor, please help Fox 1987 - 1996 F150 & Larger F-Series Trucks 5 07-22-2008 01:49 PM
Failing Pressure Test KTA-The Bull Ranger & B-Series 3 08-06-2003 02:38 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
